DVI or SVGA over 15 metres
Discussion in 'Cables & Switches' started by bri.s, Aug 26, 2005.
  1. bri.s
    bri.s
    Aug 6, 2005
    284
    28
    Livingston
    +27
    Bearing in mind signal loss over 15 metres which cable would be better over 15 metres. I would prefer the DVI to DVI cable but at that distance would the SVGA to SVGA be better its to run from the pc to the bedroom which has both connections. Thanks.
  2. Big Adam
    Big Adam
    May 7, 2003
    527
    Peterborough
    +4
    You've kind of answered your own question.
    15m over DVI can be done.....at a cost. Bettercables make a 15m DVI-D cable but even they don't guarantee that it will do the job and it is generally despatched on a sale or return basis.
    Bluejeanscables claim their DVI cables will run 1080i over 50ft which is pretty impressive.
    All depends on the 'oomph' of your output signal. You could introduce an amplifier but then your budget increases even further.
    Have a word with Joe Fernand of TMF Solutions. He is a Bettercables supplier and may be able to lend you a 15m cable.
  3. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    do the VGA, won't notice much difference and will save much money!
