DVI or Component?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Brakeinup, Oct 23, 2005.
  1. Brakeinup
    Brakeinup
    Hi, I am looking for a dvd player for my Acer 32" lcd. The screen has both component and dvi inputs. Audio would be handled via optical.
    Would you recommend to get a dvi capable dvd player or will component outs be sufficient?
  2. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,569
    worthing
    +176
    i think this realy depends on the player. on many players component provides a better or equal picture to digital outputs.
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Try them both.
  4. mark pallister
    mark pallister
    Mar 1, 2005
    88
    i would get a player with dvi or at least one that upscales to the reselution of your tv
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,990
    The Borders
    +3,599
    Hello Brakeinup
    Your question should be 'Is a Digital connection better than an Analogue connection?' - and the Answer is 'Maybe!'.
    YUV 'Component' video signals can be transmitted over a Digital (DVI/ HDMI) or Analogue (in most cases 3 x RCA) interconnect.
    The same Video signal flows down the Digital (DVI) and Analogue (3RCA) connection in your theoretical system - so the real world differences are down to how badly (or not) any Digital to Analogue and Analogue to Digital conversions that go on within the Source and Display when using the Analogue 'Component' connection happen.
    Many folk assume Digital is best and this is not always true - the most recent DVD players are likely to have more time and effort spent on ensuring the Digital (DVI or HDMI) Outputs offer the best connection on any given Player; though your still depending on the Screen to have a well Implemented Digital Input and video processing circuitry.
    If you have both Analogue and Digital Inputs on your Screen plus Analogue and Digital Outputs on your DVD player then try both connection methods - keep in mind too your Screen will have to be HDCP compliant on its Digital Input if your chosen player has an HDMI or DVI with HDCP Digital Output.
    Best regards
    Joe
  6. Brakeinup
    Brakeinup
    Thanks for all of your your responses - much appreciated!
    My screen is HDCP compliant (Acer AT3201W) and does have both types of connection.
    I think I will follow your advice Joe and get myself a dvd player that has both outputs. I do want to get the best out of the screen as I can so time for some testing!
    (This has also made me decide to put both a dvi cable and a component cable in the installation - all of the cables are going to be sunk in the wall).
