DVI or 15pin D-SUB is there a big difference in PQ
Discussion in 'Desktop & Laptop Computers Forum' started by WIRY, Jul 27, 2003.
  1. WIRY
    WIRY
    HI ALL
    Just wondering if any one out there has tryed both the DVI and Normal 15pin to connect
    their PC 2 their plasma, and seen a noticable change in PQ
    This also applies for dvd playing from PC to Plasma
    thanks to any one who takes the time to reply
    cheers
    wiry:smoke:
  2. Kramer
    Kramer
    Not a plasma, but the differences between DVI & VGA to an LCD monitor is pretty pronounced.
    Sharper by miles, far higher contrast & colour saturation etc...
    I'd imagine the differences should be similiar with a DVI equipped plasma display.
    DVI to digital projectors (eg. HS10) is also quite a bit better than VGA.
    All this is assuming you can successfully send a 1:1 mapped signal via DVI.
    :smoke:
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,258
    Manchester
    +753
    The problem with sending VGA to a plasma (or other true digital display) is that VGA is an analogue output signal type (RGB + TTL Hsync & Vsync, AKA RGBHV) .
    Thus the VGA signal would have to be converted in to digital (fast analogue to digital converter - ADC) within the display device. The ADC will produce its own errors (linearity & quantisation errors for example) .
    DVI - digital out with the correctly mapped/formatted signal avoids these processing errors , resulting in a cleaner output.
    Chris Muriel, Manchester.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There you go wiry, the tech heads here seem to think the same as me. It's the way to go all other things being equal. Had a play with all this with Phil of UVEM and a Pio.503mxe, the results via DVI were truly awesome, and have persualded me to upgrade my projector to a DVI model, been thinking about it for a year or so.
