DVI or 15pin D-SUB is there a big difference in PQ
Discussion in 'Plasma TVs Forum' started by WIRY, Jul 27, 2003.
  1. WIRY
    WIRY
    HI ALL
    Sorry if ths should be on the HTPC colum, just wondering if any one out there has tryed both the DVI and Normal 15pin to connect
    their PC 2 their plasma, and seen a noticable change in PQ
    This also applies for dvd playing from PC to Plasma
    thanks to any one who takes the time to reply
    cheers
    wiry:smoke:
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Try the PC forum, but I've done it many times, and I hate to tell you but it depends on the screen. Pioneer show a magnificent improvement, Fujitsu require hours of tweaking to work properly, then are better than VGA, love to play with the panny 6, will get one soon I hope.
