DVI option - gone..:(
Discussion in 'PC Gaming & Rigs' started by museumsteve, Jun 27, 2003.
  1. museumsteve
    museumsteve
    Jan 28, 2001
    7,919
    4
    Nth Hampshire
    +1,070
    anyone have any idea why suddenly my geforce 4 wont output DVI.?
    I've been using PC on my HS10 through DVI for months and never had a problem. The last time I remember using it was when I watched T2 Extreme HD version..
    I've updated drivers, roll them back and uninstalled..everything. but nothing helps.
    When I go into nView, and try Detect displays it doesn;t bring up a digital connection anymore. I have searched high and low on the web and cant find anything at all..
    I'n running XPpro, geforce 4 ti4600 and a fairly healthy PC.
    Question..would/should the digital connection option show if the DVI equipment it was plugged into was not working properly..(if you know what I mean). I;m just hoping my HS10 is okay but dont have anything DVI to test it.
    finally, the DVI works when using DVI-VGA adaptor into normal monitor
  2. I am maximus
    I am maximus
    Nov 14, 2000
    76
    Surrey,UK
    Hi Steve
    I had the same problem from my pc to the monitor it turned out to be the monitor which was only a week old!!!I also have a nvidia card running xp pro on a 128mb graphics card by Asus I tried everything including drivers etc etc but it turned out to be monitor.I hope this helps old boy.regards your old Sony pal
