Dvi on playstation 3?
Discussion in 'Playstation Forums' started by chemicalbrother, Oct 24, 2005.
  1. chemicalbrother
    chemicalbrother
    I know the playstation 3 has hdmi connection and the anologue connection composite and s video and component but will it have a dvi connection? or some sort of hdmi to dvi adaptor?
  2. matt_p
    matt_p
    Apr 7, 2005
    851
    28
    Nottingham
    +38
    You can buy HDMI > DVI adapters for a few quid, or HDMI > DVI cables for a bit more.
  3. chemicalbrother
    chemicalbrother
    what like the vga to dvi adaptors? that sort, will this affect picture quality in any way?
    thanks for replying
    dan
  4. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    It may not be possible with the PS3 to use VGA as it doesnt support HDCP.
    The PS3 will only work with HDMI or DVI-D with HDCP.
    Thats one of the downsides of having a Blu Ray drive in the PS3.
    (Blu Ray will only work with HDCP conections)
  5. matt_p
    matt_p
    Apr 7, 2005
    851
    28
    Nottingham
    +38
    VGA > DVI adapters are used when going from DVI-I (DVI-integrated) to VGA (or vice versa). DVI-I sends both analogue and digital signals, the analogue signal being the same as VGA. You're not seeing a drop in pic quality, you're just seeing the analogue one.
    HDMI > DVI should give you an identical picture, although some source/display combinations can see slight differences due to different colourspace info being sent over HDMI/DVI. Best to just try it and see I'm afraid! If you can adjust colourspace info, sometimes this can correct problems.
  6. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    The type of DVi used in plasmas and LCDs is DVI-D. (With HDCP)
    Its not the same as DVI-I. (No HDCP)
    DVI-D is interchangable with HDMI but DVI-I isnt.
  7. matt_p
    matt_p
    Apr 7, 2005
    851
    28
    Nottingham
    +38
    Not sure where you got your info from... Example off the top of my head, Philips 9986 LCD has a HDCP enabled DVI-I socket. DVI-A obviously can't carry HDCP, as it is all analogue. But I can't think of any screens with DVI-A, so that's a moot point.
    Being DVI-D isn't a guarantee of HDCP compatibility, nor is DVI-I a guarantee of incompatibility. It's up to the manufacturers whether they put it in. :lesson:
  8. chemicalbrother
    chemicalbrother
    yeah i was thinking of some thing complicated getting in the way of that, yeah i was thinking hdcp would be needed dam oh well ill have 2 get one of them amazing 26inch samsung lcd monitors!!!!!!!!!! lol
