DVI into a 4805
Discussion in 'Projectors, Screens & Video Processors' started by abspag, May 19, 2005.
  1. abspag
    abspag
    :lease: Can anyone tell me why I have lost the option for letterbox in the aspect ratio menu since I changed the connection from component to DVI I used to get the options 4.3 16.9 native and letterbox And now the option for letterbox is not on the menu or an option on the remote :confused:
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Can't be specific but DVI input often results in the loss of some menu options... colour adjustment is another one from memory...PJ :)
  3. abspag
    abspag
    Thanks I am sure I still get colour adjustment but I will check later
