DVI-I -> SCART RGB
Discussion in 'Desktop & Laptop Computers Forum' started by davrouk, Mar 13, 2005.
  1. davrouk
    davrouk
    First post and newbie to the home-media hardware scene.
    I have been reading the excellent VGA -> SCART RGB threads, and am interesting in doing something similar with my recently purchased mac Mini (it was initially just to be a second computer but would serve better as a media-centre due to its tiny size).
    The mac Mini uses a Radeon 9200 with a DVI-I output connector.
    Is there a modification to the VGA -> RGB cable that would allow straight DVI-I -> RGB?
    If not, would the DVI -> VGA adapter that comes with the computer be acceptable to connect the VGA -> RGB cable to?
    There are two similar apps to PowerStrip available for mac which would both allow customization of the resolution and timings, so that should not be a problem.
    (obviously this all assumes that the 9200 in the computer does output the composite sync signal as the PC version does, but it is exactly the same chipset so I dont see why not?)
    Any help on this would be appreciated
    Paul
  2. Werner
    Werner
    from a purely theoretical standpoint, yes, it would work.
    dvi-i --->vga adapter--->rgb scart cable
    mac software
    happy days :D
  3. stlic
    stlic
    Feb 17, 2004
    769
    +19
    It will work fine using the adaptor.
