DVI-i or DVI-D - which one ?
Discussion in 'PC Gaming & Rigs' started by kenjolly, Jul 12, 2004.
  1. kenjolly
    kenjolly
    Mar 11, 2001
    101
    Blackpool
    +5
    Hi all,
    I'm about to take the plunge and get a 17" TFT - I've found one I think is good at a reasonable price - the Ilyama prolite E431S. This has a response rate of 16ms which is quite good but also has a DVI interface.
    I have a geforce 3 ti200 (Sparkle) which has a DVI connection - my problem is I don't know whether it is a DVI-I connection or DVI-D connection (the latter is the connection on the monitor).
    The difference seems to be one is 24 pin (DVI-D) and the other is 29 pin.
    Anyone know if you can connect this monitor to a geforce 3 - are all DVI connections on a graphics card the same ? I know I can connect using the VGA but that seems to me to defeat the purpose of a digital display !
    Any help / comments appreciated. Thanks for viewing.
    Kenneth
