DVI-I or DIV-D
Discussion in 'LCD & LED LCD TVs Forum' started by Starfish_001, Apr 15, 2005.
Tags:
  1. Starfish_001
    Starfish_001
    I've just bought a Hitachi 32LD7200 and want to connect a pc among other things but what is the best conection? VGA vs DVI
    I guessing DVI is the answer but What cables would I need a DVI-I or DIV-D
    Will a DVI-I fit on the TV?
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi Starfish,
    For a start, VGA sends an Analogue signal and DVI can either be Analogue or Digital.
    DVI-D sends a digital signal
    DVI-I can send either digital and analogue signals.
    What I have done with my set up is connect the VGA out on the laptop to a VGA cable, then use a VGA to DVI-I adapter and plugged that into the Sharp TV. This used an Analogue signal. What you can't do is take a VGA signal and connect it to DVI-D (Digital).
    You need to check the TV's DVI input becuase there is a physical difference between DVI-D and DVI-I (There are 4 extra pins on a DVI-I plug that would not fit a DVI-D socket).
    Some people say that VGA produces a brilliant picture, but I would personally go with DVI-D.
    HTH,
    Richie.
  3. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    What's youre opinion so far then Starfish?
  4. Starfish_001
    Starfish_001
    Xelon,
    It looked great in the shop among the best I've seen - but my one has not arrived yet.
    My problem is I'm not sure waht connector it has DVI-I or D
    Just wanted to make sure that I had all the cables and stuff ready for a quick setup - otherwise my Girl friend will shoot me for wasting my time
