DVI-HMDI 8 meter
Discussion in 'Cables & Switches' started by Spooksta, Apr 26, 2005.
  1. Spooksta
    Spooksta
    Nov 7, 2000
    2,652
    Planet Earth
    +275
    Going to need an 8 meter one for a Denon 1910(DVI) - Pany AE700(HDMI)
    Anyone recommend one ?. Also thought about HDMI-HDMI and buying a £20 convertor ?
    Your thoughts please :)
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,805
    The Borders
    +2,471
    Spooksta
    Look at the banner add below this Post for an idea what we use/recommend.
    8m can (though not always) be problematic where you have DVI involved - if it was HDMI to HDMI 8m is not usually a problem.
    Unless there's a valid reason for introducing one I'd try and avoid the adapter if possible and stick with a DVI to HDMI cable.
    Best regards
    Joe
  3. Spooksta
    Spooksta
    Nov 7, 2000
    2,652
    Planet Earth
    +275
    Had looked at links but wondered what other people had bought in my situation. So there is no guarentee that 8m dvi-hdmi will work? and if it dont i get a refund ?
    Is it realy worth the extra money or should i just stick with Components ?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,805
    The Borders
    +2,471
    Hello Spooksta
    Any cables we supply are on a Sale or Return basis - and I'm sure a few of the other Forum sponsors will offer similar flexibility.
    DVI was only ever designed for computer applications and anything over 5m can be a gamble - that said we have supplied lots of 8, 9, 12 and 15m DVI cables and our 'returns' rate is very low.
    Best regards
    Joe
  5. Spooksta
    Spooksta
    Nov 7, 2000
    2,652
    Planet Earth
    +275
    K m8 cheers
