dvi help needed!
Discussion in 'Cables & Switches' started by jasonx32, Dec 11, 2004.
  1. jasonx32
    jasonx32
    Oct 7, 2004
    242
    19
    Does anyone know if it is possible to join two dvi-d cables together using some sort of female to female dvi-d adapter block and if someone makes such a thing?
    Tried maplin, ebuyer and all the usual places but nothing, only male to femail adapters.
    Ta.
    Jason
  2. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    Hello Jason,
    A quick google search finds these
    Remember that DVI can be a problem at long lengths ( 10 Metre +) with high resolutions, unless you buy a quality cable.
    worth a try though !
    Mark.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,275
    The Borders
    +2,572
    Hello jasonx32
    We use a whole range of Gefen adapters – DVI/DVI, DVI/HDMI and HDMI/HDMI to join two cables together (see http://www.gefen.com/kvm/products/adapters.jsp)
    As Mark points out the potential ‘problem' with extending DVI cable's is how well your set up copes with the length of cable your hoping to achieve.
    Best regards
    Joe
