DVI/HDMI switch boxes? Do they exist?
Discussion in 'LCD & LED LCD TVs Forum' started by Gortz, Sep 19, 2005.
Tags:
  1. Gortz
    Gortz
    Does anyone know if I can get hold of a swicth box that I can put both dvi and hdmi cables into that will then go to a single hdmi input on a tv? If they do exist what is the quality generally like?
    The problem being I need to potentially connect an xbox 360, ps3 and a computer all digitally and no manufacturers seem to have a panel that would do that many inputs.
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Yes but they are currently expensive - wait until you actually have an xbox 360, PS3 and PC. Most/all will not switch the analogue side of DVI-I. Is the xbox 360 digital? There should be no picture degradation - infact some, like the Meridian 421 may actually enhance the picture especially over longer cable runs.
    -Ian
  3. nogimmix
    nogimmix
    Dec 4, 2003
    2,120
    Kent & Canary Wharf
    +82
    Isn't the Xbox360 component and vga.
  4. daz1976
    daz1976
    Jul 13, 2005
    138
    Norwich
    +21
    Did read today that the UK XBox 360 bigger pack (£279) will come with a hi-def lead via component connection not HDMI.
    Daz
