Dvi+hdmi+powercable?
Discussion in 'AV Receivers & Amplifiers' started by Mausse, Nov 7, 2005.
  1. Mausse
    Mausse
    I'm moving all my cables into the wall. All the cables are high-end i've tied them all together including the powercable. Will the powercable cause any trouble this way??
    Please help! Thx!
  2. saibot
    saibot
    Jun 28, 2004
    1,240
    Near the Lee - Ireland
    +42
    what I did was put the power cable in a seperate piece of trunking, and ran all the video cables (component,composite,s-video) in another piece of trunking alongside, and dont see any issues.
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Power should be run a separate route or be in shielded trunking. However length of run, quality of cables and quality of mains supply all have varying ammounts of effect.
  4. Mausse
    Mausse
    i can run it in another plastic tube, can i shield it with silverpaper??
  5. Mausse
    Mausse
    can somebody help me out about the silverpaper, will it work???? Would like to finish my project 2 nite :thumbsup:
  6. Mausse
    Mausse
    anyone!?
  7. hufartd
    hufartd
    Mar 13, 2005
    468
    46
    +109
    if you connect the silver paperto earth it will help ..............
  8. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Not exactly proffesional but it should work...
  9. Mausse
    Mausse
    thx for the input, i bought the wrong cement can't finish it tonight arggggggggg.... :suicide:
  10. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I can't see it causing any problems at all. 13A mains runs at 50Hz whilst DVI/HDMI are much higher frequency signals which won't be affected by mains frequencies. :)
  11. stevefish69
    stevefish69
    Jun 25, 2004
    4,313
    +532
    Why not run the mains cables in lengths of Adaptaflex.
    http://www.adaptaflex.co.uk/home-f.htm
    We use this at work to shield the mains cables from spiking the ultra sensitive speed Encoder cables on Lifts. Just Earth the source end and a jobs a good un.
    Steve
    Thinking of it, i might grab myself a roll :devil:
  12. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    And what happens if you have 'dirty mains' with lots of high frequency spikes? The problem with theory is that it often deals with ideal situations, and practical situations are seldom ideal. It may work fine, it may not. Better to be safe.
  13. Mausse
    Mausse
    hmmm that's even more confeusing? I have the powercable in a plastictub covered with silverpaper and will finish up the wall tonight. I'll make a picture (for the freakzzz ;)
  14. Mausse
    Mausse
    Haha i consider myself a semi-pro now :clap: will make a snap when it's done.......after i installed the philips 37pf9830 + B&W MT-30 and a yamaha rx-2600...can't wait...... :thumbsup:
