DVI/HDMI conversion
Discussion in 'Blu-ray & DVD Players & Recorders' started by jonan73, Jan 22, 2005.
  1. jonan73
    jonan73
    Hi!
    Do you know if tehre is any way (adapters?) to convert a DVI signal to an HDMI signal? I'm thinking about buying the Arcam DIV79 and a Sanyo projector. The projector I want only has HDMI and I woudl love to be able to (occasionally) hook up my laptop to this projector (DVI output).
    Many thanks!
    Johann
  2. Blue2
    Blue2
    I belive you can use any DVI to HDMI cable, best bet seems to be CPC. www.cpc.co.uk search for HDMI.
    Check that your laptop has a standard DVI connection.
    b
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Alternatively Lektropacks has what you need, both cables and adaptors going in both directions.
  4. jonan73
    jonan73
    Many thanks for your help! :)
    Johann
