DVI full screen on 32PF9986
Discussion in 'LCD & LED LCD TVs Forum' started by Diving Bear, Jan 27, 2005.
Tags:
  1. Diving Bear
    Diving Bear
    I'm not sure which forum to post this on LCDs or DVD Players... so have gone for both!
    I have a Philips 32PF9986. I have just bought a Denon 2019. When I connect it through the DVI it dosplays the screen with black boarders. I am unable to use the movie expand 16:9. When I change to RGB scart I can use the expand and get the whole screen, but the picture isn't as good.
    Is it possible to get a full screen picture using the DVI input??
  2. Alan D
    Alan D
    It will be full screen (excluding expected borders with movies) at 576p and 1080i. But there will always be a border at 720p as the Philips shows a "pixel matched" image of 1280x720 and the screen is 1366x768. If you have any problems centering the image on screen, the TV remote cursor keys to nudge it left/right and up/down.
