DVI equipped DVD players?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Messiah, Apr 2, 2003.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Anything available yet or what is on the horizon?
    Thanks.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Messiah,
    Yes, there is the Samsung DVD-HD931 with Faroudja DCDi and DVD-Audio. This player will supposedly upconvert an NTSC 480 progressive signal to output a 720p or 1080i signal from the DVI-HDCP output. It will be available from June in the US at a reasonable $350.
    Steve
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Linn Unidisk. SHipping end of this month I believe....ALOT more than $350....No Sage chip...but bet it's still better!
    Gordon:rotfl:
  4. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Thanks guys. Would be happy to go with the Samsung as for that (little) money it's gotta be worth a try.
  5. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Try here
    Don't the americans seem to have the best toys...
    I predict 2004 will be the year for DVI players.
    Ian Guinan
  6. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Me thinks I may order one if I still have the TW100 :(
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Remember that you MUST have HDCP enabled DVI inputs on your displays.
    I'm not sure about the DVI thing myself. Mainly as you end up being limited in the de-interlacing dept by the DVD player. Ideal would be SDI out but that's not going to happen so it's going to be interesting to see how this all pans out....
    Gordon
  8. 876
    876
    Momitsu 880 (Sigma 8500 based) - ~230$
    Bravo D1 (Sigma 8500 based) - ~ 200$
    Marantz 8300 - ( with Faroudjia) - ???
    Philips Q75 - (with Faroudjia) - ???
  9. EvilMudge
    EvilMudge
    Sorry to jump in, but I'm also looking forward to DVI-D equipped DVD players.
    Gordon, how does a DVI interface limit the de-interlacing options to the player only? Surely it depends on where the interface driver IC is placed in the signal chain. I accept that the vast majority of manufacturers are thicker than two short planks in this regard and will put the panel interface down stream from the de-interlacer, but it is possible to insert the interface between the de-interlacer and the MPEG decoder. Surely then it would work just as well, if not better than, SDI?
  10. EvilMudge
    EvilMudge
    Okay, did some research.
    What I was proposing would work, but the only thing that could accept the output from an interlaced player would be a specially designed off-board de-interlacer, unless you like your pictures with black lines between them.
  11. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    The DVI interface DOESN'T support as low a bandwidth as 480i or 576i. So anything going down DVI must be at least 480P. Hence it has to be de-interlaced inside DVD first
    Gordon
  12. EvilMudge
    EvilMudge
    Gordon,
    It doesn't properly support 480i, as in you won't get a picture you can display from an interlaced source, but theres nothing in the VESA spec that stops it from working.
    You're right though, SDI into something like an HD-Leeza or Key Digital PioMXE is the way to go with DVD playback. How much is the Leeza BTW? I see this and the Tag PSM+Scaler as being direct competitors.
  13. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Gordon,
    Do you have any further info on the proposed Key Digital SDI-DVI adapter that you mentioned a while back?
    Steve
  14. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  15. Mark4
    Mark4
    May 2, 2003
    32
    London
    There's a report of a user demo on Topica that says that the DVI port is not enabled on the Linn Unidisk.
  16. EvilMudge
    EvilMudge
    I hope they connected it up to an HDCP compliant display, either wise that news is worthless.
  17. Mark4
    Mark4
    May 2, 2003
    32
    London
    Apparently in the manual it says "the DVI port is not currently enabled".
  18. EvilMudge
    EvilMudge
    :laugh:
    Oh well, guess we'll have to wait for the firmware upgrade.:smoke:
  19. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  20. wswong
    wswong
    I'm waiting for DV-30 from Teac !
    [​IMG]
    [​IMG]
  21. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Any ideas when it is due out and how much?
  22. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    A DVD without a SCART won't be popular in Europe!
  23. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    "A DVD without a SCART won't be popular in Europe!"
    Unless you use a Plasma or projector.
    To be honest, I don't think even a 32" w/s tv will realise the potential of a lot of these high end players.
    Gary.
  24. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    I agree.
    when i said it won't be popular i intended: they won't sell lot's of dvd players as they would if they put a SCART in it!
    maybe 90% os dvd owners use a SCART to connect to TV...
    Plasmas and projectors are not the majoraty...
    I'm buying a projector but still i have a tv and intend to use it!
  25. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    "they won't sell lot's of dvd players as they would if they put a SCART in it!"
    Actualy you're probably right, even more so if it gets good reviews.
    Some of thje players I'd be interested in don't have component, and as I need it for my pj, means it's off my list of players to consider. Oh well... :)
    Gary
  26. philipb
    philipb
    Mar 6, 2002
    2,060
    63
    Swindon
    +153
    Remind me guys - is the DVI input on a Pioneer 433 plasma HDCP compliant? I think not unless you have the new KD card installed?
  27. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi philip,
    You're right, the standard PDA-5002 card isn't HDCP compliant. You would need the KD card or one of the 2 new ones from Aurora. See www.auroramultimedia.com for details.
    Steve
  28. philipb
    philipb
    Mar 6, 2002
    2,060
    63
    Swindon
    +153
    Thanks dutch.
    Seems my options are narrowing to one of the following - the KD card, the TVP-1000+ or the A303-HDCP (which looks to be seriously short of inputs).
    So any views guys on the best route to take, and how much better would a DVI DVD player like the Teac be compared to my Denon 3800 connected via component? I have a sneaky feeling the scaling will produce the main benefit - all digital feed via DVI being better but maybe not much than analogue component.
    Is there anywhere I can see these things working? Gordon or one of your dealers - will there be demos of the KD card when it arrives? £1700 is a lot to splash out before knowing it will deliver real improvements.
