DVI DVD Player to go with Hitachi PD5200
Discussion in 'Plasma TVs Forum' started by BoomBoom, Aug 26, 2004.
  1. BoomBoom
    BoomBoom
    Hi all,
    I am getting a PD5200 Plasma and wanted to know what is the best DVD Player to put with that. I read in What HiFi that the Samsung DVD-HD935 is good and has DVI for £150 but can't seem to locate one. Is the 945 the same but better?
    Your advice would be greatly appreciated.
    Thanks Boom :smashin:
  2. Hicksy
    Hicksy
    i too am looking for a dvi dvd player. the new samsung HD 945 got very good ratings in one of magazines. its the one i am going for and is only £165.
  3. BoomBoom
    BoomBoom
    thanks Hicksy Do you know which Mag has reviewed it?¿
    Also where are you buying from? Is that the cheapest place?
    Thx
    Boom :beer:
  4. Hicksy
    Hicksy
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,479
    +2,382
    Where from and just how much of an improvement over comoponent would they be
  6. Hicksy
    Hicksy
    from the above thread. from what i have read DVI will make a big difference. for that money worth the risk i say.
  7. BoomBoom
    BoomBoom
    I am hoping it will make a big difference otherwise why am I sending all this money :devil:
  8. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    Just because a player has DVI or HDMI doesn't necessarily mean that it will give the best picture. Samsung don't have a great track record in dvd player design and What HiFi reviews can be a bit :zonked:, for example, they spent a long time slagging off the Hitachi plasmas and now rate them better than the latest Pioneer - go figure. There is much more to PQ than just the digital interface. If the drive and MPEG decoder aren't up to scratch, then DVI, no matter how good it is will improve the picture. Consider also the quality of the audio processing in the player, another area that others have been much better at.
    Just food for thought :rolleyes:
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,412
    The Borders
    +3,229
    BoomBoom
    I don't know the Hitachi model specs too well but I cant see HDCP support on the DVI input - which means unless you find a non HDCP Player with DVI out your snookered for playing Commercial DVD's.
    The Samsung HD-945 is HDMI which will be HDCP - so no good; possibly someone has info on non HDCP players or can confirm if the Hitachi Display is HDCP enabled.
    Best regards
    Joe
  10. BoomBoom
    BoomBoom
    Thanks for the advice - Jees...didn't realise it was soooooooo complicated. Does anyone have any further advice?
    Ta
