DVI DVD player for Panasonic 6-series plasma
Discussion in 'Blu-ray & DVD Players & Recorders' started by lmccauley, Jul 4, 2003.
  1. lmccauley
    lmccauley
    Oct 24, 2000
    3,472
    Newcastle
    +291
    Can anyone recommend a DVI-HDCP equiped DVD player that I could hook up to a Panasonic 6-series plasma?
    Budget would be no more than £500.
    Would be to replace a Pioneer 545.
    Cheers,
    Liam
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    The Bravo D1 and the Momitsu DVD V880 both have DVI, but not sure if the Bravo is multi-region. Hivizone sell the Momitsu:
    http://www.hivizone.com/
    Go to avsforum for more info on both players. The D1 gets good reviews with the NEC HT1000 projector. The Momitsu seems like a garage built machine by one man, but I could be wrong. Best to check.
    HTPC will be a cheaper option (and far more flexible), but you need to be fine about setting up the software and maybe having to tweak. A desktop case could be used to hide it in a tv or video rack maybe. Any Radeon card with DVI out should do the trick.
    HTH
    Gary.
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,472
    Newcastle
    +291
    Would the display device (which has a DVI-HDCP input) accept a non-HDCP DVI signal from a HCPC? Sorry for the simple questions - this is the first time I've even thought avout DVI.
    Cheers,
    Liam
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Liam,
    Yes, it would take it from an HCPC.
    I'm waiting for a replacement Momitsu to arrive from Hivizone after I had to return my original faulty player. I hope to feed it to my 433MXE via the PDA-5002's DVI, but I'm limited to 480p until I replace the card with a new Aurora or KD one.
    Steve
