DVI-D to DVI-D or HDMI to DVI-D?
Discussion in 'Cables & Switches' started by wilhock, Dec 4, 2004.
  1. wilhock
    wilhock
    HI, new to the game...
    Anyone have a view on which connection would be best to link a DENON DVD 2910 and a Hitachi 42PD5200?
    Is there any benefit in using the DVD's HDMI out or should I stick to a DVI-D to DVI-D lead?
    Are the video signals the same? My DVD manual says that if I do the HDMI output to DVI-D input then '...the signals are output in digital RGB regardless of the HDMI/DVI select setting'. This sounds an inferior output to me?
    Help please on the above and any advice on good makes of cable also apreciated.
    TVM
