Dvi-d to dvi-d on Plasma-no picture.
Discussion in 'Cables & Switches' started by chuffster2005, Jan 6, 2005.
  1. chuffster2005
    chuffster2005
    Dec 27, 2004
    540
    28
    +47
    Ok,I`ve now invested in a Denon 1910 dvd player so I can connect a 24 pin dvi-d to dvi-d cable to my NEC 50"plasma,but I can`t get a picture!HELP"!
  2. Bruce1310
    Bruce1310
    Dec 7, 2004
    227
    19
    Aylesbury, Bucks
    Firstly is the DVI input on the NEC Plasma HDCP compliant...if not you won't get a picture.
    If it is...you need to made sure the Denon is set-up to output DVI and the NEC may also have a setting to input DVI...give that a try.
    Bruce
