dvi-d to component
Discussion in 'Desktop & Laptop Computers Forum' started by rhino2k, Jan 2, 2007.
  1. rhino2k
    rhino2k
    Oct 20, 2005
    6,071
    +1,279
    just a quick Q guys, my gfx card apparently supports upto 720p/1080i, can i use THIS to get the signal from A-B ?
    thanks :thumbsup:
  2. poggs
    poggs
    Jul 21, 2004
    653
    28
    +34
    No.
    You have DVI-D (ie dvd digital) That is for DVI-I (analogue) You need a full on convertor at around £lots to convert dvi-d to component!
  3. rhino2k
    rhino2k
    Oct 20, 2005
    6,071
    +1,279
    i think i made a slight mistype, my card is dvi-i afaik, specs for it are HERE.
    anyone know if this will output component via above cable?
    thanks :smashin:
  4. rhino2k
    rhino2k
    Oct 20, 2005
    6,071
    +1,279
    after a quick look around, i think i may be ok!
    my card had a lead that splits into component, the basically same card is HERE, mine just has 2 dvi-i outputs. i'm just hoping the component will output at 720p/1080i.......
