DVI-D projector image problems
Discussion in 'Computer Components' started by mark05, Jan 29, 2009.
  1. mark05
    mark05
    Jan 12, 2006
    23
    Banbury
    Hi All,
    I'm having some trouble with DVI image quality on a dual head graphics card:
    I have a PC with monitor and projector, I want to have a cloned desktop setup with the VGA output to the monitor and the DVI to the projector.
    As all this is installed in a lecture theatre at work I tested things first with a short DVI-D cable and all was fine, but when I got a longer (3m) DVI cable things all went horribly wrong: The image on the projector is garbled unless I set the aspect ratio to letterbox (needs to be wide for 1280x768), then it is all squashed and loses the top and bottom of the image!
    Things I have tried so far:
    1.5m DVI-D cable and cloned desktop - good picture
    3m DVI-D cable and extended desktop - good picture
    3m DVI-D cable and cloned desktop - garbled picture
    The reason I'm doing this is because we are currently using the VGA input on the projector through a splitter and VGA switch to provide for laptops, doing this we get shadowing even bypassing all the switches - text looks smudged.
    I'm not sure how long the cable is to the projector, I'd guess it could be up to about 6 or 7 metres, so plus the cable to the PC it could be 10m.
    Has anyone got any idea why this is all going so horribly wrong or what I could try instead?
    I need to get a good image on the projector primarily, with facility to plug in a laptop too.
    Thank you
    Mark
