christpunchers
Hi there, just wondering if there's anybody out there with some experience in this matter:
My friend and I have been looking desperately for a good quality external converter that can help the often poor analog output of most consumer PC videocards. We use high resolution CRT monitors for our work, the 1920x1200x85hz Sony FW900 24" CRT.
The most suitable item we have ran into is this:
(http://www.provantage.com/startech-dvi2dvi~7STRV01K.htm),
it does DVI-D to DVI-I, however it only goes up to 1280x1024.
Sorry if I sound confusing. All I want to do is to avoid using the analog output of the average consumer grade videocards today and try to utilize the picture perfect digital/dvi output.
However since I'm using a CRT, it needs to be fed an analog signal. So in this case, I will need an external converter of a more professional approach to take the DVI signal from the PC and convert it into an analog signal.
As long as the digital to analog signal is converted outside of the computer case, and is able to sharply display a resolution of 1920x1200x85hz, I'll jump the gun and buy it (if it has bnc outs that's even better!).
Does such a product even exist?
Thank you in advance. Cheers!
