DVI-D(HDCP) & Sky HD?
Discussion in 'Sky Digital TV Forum' started by kebamo, Mar 24, 2006.
  1. kebamo
    kebamo
    Aug 14, 2005
    28
    I have just recieved an email from sky offering me the oppurtunity to sign up for the new HD service.
    My tv is marked as being HD ready but all i can assume is that Sky HD will need to be connected by the DVI-D(HDCP) port on my TV.
    All the postings i've seen so far state that the new Sky HD box will need a HDMI compliant TV, is there anyway i can convert a the DVI-D(HDCP) port on my tv to allow me to connect to a Sky HD box.
    Is it just a simple case of a DVI-D(HDCP) to HDMI cable.
    Thanks in advance
  2. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +287
    Yes - as long as the DVI port supports HDCP, it shouldn't (theoretically) require anything more than a physical adaptor to work with HDMI.
    Gav
  3. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    If it is truely HD ready and doesn't have a HDMI port, the DVI port should be HDCP compliant - which should work.
  4. jay_edinburgh
    jay_edinburgh
    Do you not have component connections on your TV because you can also use that to connect to the Sky HD box.
  5. kebamo
    kebamo
    Aug 14, 2005
    28
    Thanks people
