DVI-d & DVI-a Difference???
Discussion in 'Cables & Switches' started by SoloSid, Jan 22, 2008.
  1. SoloSid
    SoloSid
    Jan 10, 2008
    58
    Hi all
    I'm looking to connect my HTPC via the Dvi to my 'new'
    onkyo 605 into the hdmi port...
    questions as follows...
    whats the difference between -d & -a ???
    How can i find out which i have ???
    what difference would it make to picture connecting through the DVI to HDMI instead of the VGA cable directly to the TV ???
    I realise DVI will not carry sound and this is done though twin phono cable already
    cheers
    Mark
  2. Jamie
    Jamie
    Jun 27, 2007
    5,289
    2
    Harrogate
    +1,368
    d is digital. equivalent to HDMI without sound and can be used with a HDMI adapter. You'll find you need to use a HDTV resolution to make it work so resolution choice is not so wide as using VGA or a dedicated PC DVD-D
    a is analogue. generall carries a component signal
    I is both, i.e can accept/transmit d and a.
    Whats your graphics card?
  3. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
  4. SoloSid
    SoloSid
    Jan 10, 2008
    58
    its a geforce 7600 gs
    cheers
    Mark
  5. Jamie
    Jamie
    Jun 27, 2007
    5,289
    2
    Harrogate
    +1,368
    AS far as I can tell your GPU isn't HDCP enabled. but it is DVI-I i,e can be used either digitally (into HDMI) or analogue (into VGA port) so the choice is yours
