DVI connections between Marantz equipment
Discussion in 'Plasma TVs Forum' started by Plasmaniac, Nov 3, 2004.
  1. Plasmaniac
    Plasmaniac
    Hi everybody, Could someone give an answer to the question if it is really true that the DVI (with HDCP) output from Marantz DVD-player DV12S2 IS NOT COMPATIBLE with the DVI input of their newest plasma screen?(PD4220V). If this is really true, could their be a workaround because both machines are very good performers indeed!.
    Best regards.
