DVI connection Plasma & DVD
Discussion in 'Plasma TVs Forum' started by BoomBoom, Sep 23, 2004.
  1. BoomBoom
    BoomBoom
    Does anyone know 100% if a Hitachi PD5200 has HDCP support on the DVI input? I am thinking about getting the Samsung HD-945 which is HDMI but need to be 100% before I purchase it.
    Thank You.
    Boom
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Yes it is. But I would still physically check that the panel and DVD will work and at the picture resolutions you want to use.
    -Ian
  3. BoomBoom
    BoomBoom
    Thanks ianh64 that is good to hear. I have been trying to get a definitive answer for ages. Hitachi say it is only to PC connections.
    Thanks Boom
