DVI connection on Hitachi 42PD7200
Discussion in 'Plasma TVs' started by wonderloaf, Aug 2, 2005.
  1. wonderloaf
    wonderloaf
    Jul 5, 2005
    264
    Hampshire
    +6
    Just tried connecting up my PC using the DVI socket on the 7200, problem seems to be that the plug (cable) side has a flat blade connector with 2 pins either side top and bottom, but the plasma side just has an aperture for the blade, no holes for the pins. Hence I can't insert the plug!
    I thought DVI connections were standard format, or is this another instance of non-standard 'standard'? BTW, used a converter to to input from DVI on the PC to analogue on the 7200 and the picture was great, but I would really like to see what it's like with DVI.
    Any ideas anyone :confused:
  2. wonderloaf
    wonderloaf
    Jul 5, 2005
    264
    Hampshire
    +6
    OK, just in case anybodies interested I've done some research and there seems to be three DVI standards: DVI-A, DVI-D, and DVI-I. Seems like I've got DVI-D on the 7200, and DVI-I on the PC (ATI Radeon AIW Graphics card). Now I've just got to find a cable that will hook the two up. For a better explanation try this link:
    http://www.lindy.com/uk/tips/uk/Digital_Monitor_Connections_Explained_/index.php
    Still, I guess you guys new this anyway ;)
  3. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    Spaghetti Junction (really)
    +1,921
    That informed me mate :thumbsup:
  4. wonderloaf
    wonderloaf
    Jul 5, 2005
    264
    Hampshire
    +6
    Glad to be of service :)
