DVI connection details?
Discussion in 'Desktop & Laptop Computers Forum' started by NoDad, Jan 1, 2004.
  1. NoDad
    NoDad
    Dec 21, 2003
    508
    West Mids.
    +25
    Well....I'm getting everything ready for the new baby (Z2 that is). By the time I've got the screen, speakers, blackout kit, PJ mount etc etc sorted Z2 should be down to <£1k :D :laugh:
    Anyway.....I intend to use DVI on PC to drive the PJ. This involves getting a cable from my "office" across the loft to the HT. This cable will be about 5m long and I intend to make my own cable (if I can find the connection details). My reasons for making my own cable is so that I can fit the cable first, without having to make large holes for the connectors.
    I am an electronics engineer, so I am happy to make this cable up, using HQ cable of course.
    Any of you guys have the details (or can provide a link) for the connections at both the PC end and the PJ end?
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    You can find the pinout for the DVI connectors below but I really wouldn't bother making your own...just make a small hole and then enlarge it to make a slot as opposed to making a huge hole.
    http://www.networktechinc.com/technote.html#dvi
    Also I'm not sure if you'd have to be carefull about getting the length of all the cables to be near enough the same or not.
    I have made several VGA cables consisting of 8 wires - I think - but you're looking at 30 for DVI if all are required - good luck !!!
    Cheers, Lee
  3. NoDad
    NoDad
    Dec 21, 2003
    508
    West Mids.
    +25
    Thanks loonatic.
    I have the pin details but I want to know specifically which pins are used at each end (or are they all required) and whether any pins are crossed over like on RS232 where TX and RX get swapped or are connections 1:1?
  4. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    Just buy one from Lindy. Not expensive and much less hassle than trying to make one. I doubt very much you'd be able to buy the connectors though. Farnell and RS certainly don't do them (or didn't a month or so ago) so I think it's one of those connection types that is kept out of the retail space as far as making them go.
    Any particular reason you want to make one yourself? Lindy sell all sorts of lengths, inc. 1m, 2m, 5m, 7.5, 10m, etc.
  5. NoDad
    NoDad
    Dec 21, 2003
    508
    West Mids.
    +25
    Thanks Messiah,
    I think I will just buy one.
  6. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    +16
    As far as I know you'd need to connect all pins except C1 through C5.
    Also...just thought, if your making the cable in-situ wouldn't you have to soilder one end in the air whilst it was hanging from the ceilling !! you could be on to a new sport - extreme soildering :D
    Cheers, Lee
