dvi colour
Discussion in 'Plasma TVs Forum' started by grayson, May 29, 2004.
  1. grayson
    grayson
    Im running my Pc to my panny6 plasma via DVI the problem is theres to much colour, is there any way I can adjust it I cant see a colour adjust on my graphics card or plasma via dvi. My card is ge forcefx im using power dvd. Thanks
  2. robbster
    robbster
    Jul 20, 2003
    394
    +13
    I'm not 100% sure on this but would changing the colour in the powerDVD configuration help?
  3. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    I use NVDVD and you have a setting called digital vibrance
    which calms the colours. may also be called saturation adjust or somthing similar
  4. grayson
    grayson
    Ive turned the saturation down and its done the trick, Many thanks
