Dvi Cables
Discussion in 'Projectors, Screens & Video Processors' started by tahirti3, May 18, 2003.
  1. tahirti3
    tahirti3
    Sep 18, 2002
    1,388
    38
    ANYONE TRIED USING A DVI CABLE AROUND 12 METRES LONG?ANY PROBLEMS?AND WHERE CAN I GET ONE FROM?
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    All capitals is interpreted as shouting...............
  3. tahirti3
    tahirti3
    Sep 18, 2002
    1,388
    38
    sorry didn't mean to shout ,but can't type to save my life.
  4. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    My post was a bit abrupt,I didn't mean to come across as having a pop at you. :smoke:
    Don't know about DVI at that length, Know VGA is ok with it. This place isn't the busiest at the weekends, someone will b along sooner or later who can give you more info.
    All the best,
    Sean G.
  5. Kramer
    Kramer
    7.5m is the "DVI standard" maximum length. Some here have had success with 10m - some have had problems & returned 10m cables & replaced them with 7.5m versions.
    Pretty much "suck it & see", but only 7.5m is guaranteed - depends very much on the resolution you need to send & the "sending" hardware.
    Lindy are probably the best suppliers (in the UK) of DVI cables - I've dealt with them & they come highly recommended.
    Been using one of their 7.5m DVI cables with 1366x768 res to a HS10 with no problems.
    :smoke:
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,152
    Surrey. UK.
    +1,956
    Good price too.
    Looks like I'll have to buy one just to see. :)
    Gary.
  7. tahirti3
    tahirti3
    Sep 18, 2002
    1,388
    38
    please tell me the benefits of using dvi over componant.i am using a sharp pgm20x and denon 2800mk2.i will be using a pc if i go the dvi way.
    thanks
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I have seen a 20m DVI cable working fine, it is alldown to length vs bandwidth.
  9. tahirti3
    tahirti3
    Sep 18, 2002
    1,388
    38
    beekeeper,any idea where i might get a longer than normal lead?
  10. Dutch
    Dutch
    Dec 5, 2002
    2,562
    3
    North Yorkshire
    +257
    Hi taherti3,
    You can get fibre optic DVI cables from www.pacificcable.com from 33' up to an unbelievable 495'! Mind you, they do cost from $435 to $3250! :eek:
    Steve
