DVI Cables
Could anyone explain DVI in a concise newbie fashion?
I'm a bit confused about the differences of the various connectors/cables, and I'm keen to try a link between HTPC (with Radeon 7500) and a Panasonic AE300 and a Toshiba MT8.
Can anyone tell me what cables I need, and where might be the best place to get them?
Thanks!
Ian Guinan
Jeff
Ian,
What size cable do you need?
Jeff
This sounds like a stupid answer, but it depends on how long the cables can be and what form they take (how thick/what colour etc).
Thinking around 10m if that is feasible...light and neutral in colour if possible.
What worries me is;
- what is the difference between DVI-D and DVI-I?
- I've read the Infocus has a different sort of DVI compatible connector (M1-D)..where do you buy an adaptor?
Do you have a supplier in mind (or just a spare one kicking around!)
Ian Guinan
Jeff
I have a 5M dual link DVI-I cable that I don't need anymore, it worked fine as a digital link between a radeon and a projector with DVI. PM me if you are interested.
Jeff
Thanks Jeff..that could get me started..I'll PM you my email address.
I found this supplier who gives quite a good description of the connector types;
Kayye Consulting
Hope this helps someone.
Regards,
Ian Guinan
Similar threads
LG CX 4K OLED TV Review: The best TV of 2020?
