Quantcast
dvi cable
ridd
rather than blindly searching the black hole that is the internet. Could someone point in the direction of a online supplier of long dvi cables please.
I think i need approx 8.5m job.
Thanks in advance for any help.
Mark
dr no
I'm also looking for good 10m DVI cables.
I read in places that lengths beyond 7.5m are compromised.
Why is that?
Somebody show us the way to good quality cables?
RobsterD
Speak to Joe Fernand @ Media Factory,I personally had problems with a 10m Lindy which a 9m Better Cables rectified,they are expensive though but IMO worth it.Another alternative is the
Cobalt which is good for 10m.
Rob
Peter Parker
I think it's meant to be a limitation of the technology:
Important!
Please note that cable lengths over 7.5m are above the recommended length laid down by the DDWG organisation who developed the specification. This factor also depends on the hardware combination of graphics card and monitor as to how far this distance can be exceeded.
Though I have seen people saying they have longer lengths with no problems. They may have been on here, but definately over on the US forum.
HTH
Gary.
Filbert
We sell GEFEN DVI cables (copper, which support resolutions up tp 1280x1024 and 720p) in the following lengths :-
1ft (0.3m)
6ft (1.8m)
10ft (3.0m)
15ft (4.6m)
25ft (7.6m)
30ft (9.1m)
40ft (12.2m)
Fibre optic based DVI cables (which support resolutions up to 1600x1200) are available in even longer lengths too.
consciouspnm
I've never found a DVI cable below 2m but you say you can get 30cm ones. Can you get anything in between i.e 50-60cm so I connect my laptop to my TFT monitor?
Filbert
The lengths in my previous post are the only ones available, sorry! If you really only want 60cm or so you could join to DVI cables together....
dr no
Filbert,
How much is the GEFEN 7.5m cable?
I have just received a Lindy 7.5m cable and it shows sparklies all over the shop.
Joe Fernand
AVForums Sponsor
waled
The Gefen DVI-C25 look like they will do the trick - though I've not tested one as yet; we use and supply most of the Gefen HDTV switcher range though carrying their complete DVI range doesn't make much sense as we already have the BetterCables Display Magic cables which suit most systems and haven't let us down so far (and there's not much in it price wise between Gefen and BetterCables).
See http://www.bettercables.com/dvicables.html
Best regards
Joe
Filbert
Waled,
Now for the answer to the question which you asked me!
The 25ft Gefen DVI cable is £141 inc VAT and P&P and they are in stock, as well as all other Gefen DVI and HDMI cable lengths.
Take a look at our web site for further details if you need to.
Joe Fernand
AVForums Sponsor
Hello Filbert
There are parallel threads going re Waled's quest for a decent long DVI cable so apologies if you felt I stepped on your toes - and watch out for the mods!!! no prices unless your a sponsor :)
Best regards
Joe
Filbert
No worries Joe, was only answering Waled's question, otherwise (as you no doubt have seen from previous posts) prices are not quoted!
ridd
Thanks for all the replys guys.
I am trying to find a good quality dvi-i cable @7.5m now. The lindys were good but were only dvi-d.
Does anyone know of a place? It has to be dvi-i with the analouge pins in.
Also im running out of time as i need it for Monday at the latest.
Can anyone help??
Mark
N
nurfen
The Marcus cable is DVI-I, £74 for 10 meters incl shipping. You won't find any better DVI cable..
mathew
is it SL too? I note the cable there for DVI-D is marked SL.
Is there any disadvantage to running in SL mode rather the DL mode if it's within the resolution SL can acheive? Since DL doubles the transmission power, is this also the case at the resolutions within SL boundaries when using a DL cable?
Similar threads
Trending threads
