DVI Cable suggestions?
Discussion in 'TAG McLaren Audio Owners' Forum' started by PhilB1234, Jul 12, 2004.
  1. PhilB1234
    PhilB1234
    Having lost out on the AV192+PSM (damn-you last second eBay bidders) that I was after I have bought a DVD32+PSM and wanted to see if anyone could suggest a DVI cable that works well......
    My questions are:
    -Is it worth spending the extra ££s on Wireworld or Monster versions,
    -I'm looking for 10m, at 576p/50Hz is there likely to be any issue?
    -What are others using?
    -Do I need to choose between Dual Link and Single Link, DVI-I and DVI-D, or does it not matter?
    Any help would be appreciated!
  2. roversd1
    roversd1
    If I remember correctly:
    DVI-I (Integrated - analog and digital)
    over certain lengths the signal can deteriorate (looks like the Matrix has taken over your screen!)
  3. babaroga
    babaroga
    Aug 27, 2003
    208
    Hertfordshire
    +4
    Phil,
    I had a bit of the play with DVI cabling. I originally needed 15m and I was able to get it in UK for some ludicrous price tag (around £300) and no guaranty that it would work at that distance. DVI cabling is specifying cable length of max 7.5m. What you would probably need to get is a DVI repeater. I myself got Gefen and imported it directly from USA http://www.gefen.com/kvm/product.jsp?prod_id=1207 . Next, I got some DVI-I cables from www.lindy.co.uk. This set up makes sure that it will work100% and should be future proof when 1080i comes into UK. Total cost for me was under £300.
    Hope that this answers your question, if you need more info, just ask.
    PS
    If you try to get Gefen Repeater from UK dealers they would try to charge you £280 + VAT for it. So much about rip off Britain….
  4. PhilB1234
    PhilB1234
    Hi, Many thanks.
    If you bought the Lindy cable it is DVI-D, not DVI-I, and by the sounds of it you got good results. I suspected the output from the PSM would be Digital only, so I think I'll try this cable.... it's certainly not overpriced!!
    Any other comments you would make? Easy to set-up, any issues with getting the two to 'talk'?
  5. kallenby
    kallenby
    Hi Guys,
    I purchased a RAM Electronics DVI-D Dual Link cable from the US - 50ft for US$250; obviously cheaper for shorter lengths. I chose the dual link over single link to future proof myself for future higher grade signals. :thumbsup:
    You can see their website at www.ramelectronics.net
    The output from my DVD32R / PSM goes into an NEC HT1100 Projector - the picture is really good; excellent on DVD, i'd recommend these cables but am not so sure on a DVI Repeater - never seen one but would be v.interested to hear from anyone on results since none exist here to view.
    Cheers,
  6. PhilB1234
    PhilB1234
    Just to add an update: I did indeed get the Lindy DVI-D cable as mentioned above (under £40!!!) and have just connected it up with marvelous results! So no problem with a 10m run, and once I'd realised that the PSM needed to be told to output RGB not component (thanks Barry!!) results were instant and very pleasing!!
