DVI Cable Question
Discussion in 'Cables & Switches' started by moid, Jun 27, 2004.
  1. moid
    moid
    May 9, 2003
    40
    Leeds - UK
    Been racking my brains about this one but with no luck.
    I have my Plasma sitting in my lounge and my computer in the room next to it with a small hole in the wall for cables to go through. But, the DVI cable has the 2 DVI connectors at either end which are way to big to fit through without making a huge hole.
    So... is there any way to take off one of the end and refasten it?
    or some other clever way of doing it???
    Im currently using an s-video to scart but this means taking out the sky scart everytime and i think the dvi would be better quality.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,390
    The Borders
    +3,228
    Moid
    A Molex DVI-D to HDMI cable + a Gefen HDMI to DVI Mate.
    Poke the HDMI connector (20mm x 10mm) through the hole in your wall and then join that to your DVI cable with the Gefen adapter - see http://www.gefen.com/kvm/product.jsp?prod_id=2186
    As ever with all things DVI its 50/50 that it will work so we normally supply these bits on sale or return as long as your happy to foot the postage.
    Best regards
    Joe
  3. moid
    moid
    May 9, 2003
    40
    Leeds - UK
    so what sort of cost are we looking at for both including postage etc
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,390
    The Borders
    +3,228
    moid
    Bearing in mind there are rules about pricing on the Forums - in round numbers your looking at roughly £65.00 all in - of which £7.20 is postage and packing.
    Best regards
    Joe
