DVI cable quality
Discussion in 'Cables & Switches' started by steve0, Sep 11, 2004.
  1. steve0
    steve0
    Sep 11, 2004
    762
    Loughborough
    +32
    Currently Im running from my computer to my panny6 via dvi cable which is a 3 metre run.
    My question is will I notice much difference in picture quaility if I used a more expensive cable rather than the one Im using at the minute which came with my PC. Thanks
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    I tried using a $100 DVi cable and notice NO or very little difference!
    However, I took that cable and used it in a very different way.
    My plasma TV (Fujitsu) has the receiver conected to the actual panel by DVi.
    It was the cable that came with the TV and was a 3m cable which felt very thin.
    So I changed it for my 1m 100dollar cable and saw a massive improvement in picture quality! I was well surprised!
    Look slike the weak link in my set up was the receiver to panel cable!
    The picture is much richer, brighter, sharper and the colours more vivid!
    PC wise, the only difference ive ever seen is between RGB (analog) and DVi (digital). The cables themselves dont seem to matter too much, still if you want peace of mind, get a slightly better one for say 30quid or so?
    Also, length. The shorter the better. If the cable is long i feel that you loose picture quality as the picture might degrade over a long cable.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,579
    The Borders
    +3,030
    steve0
    More expensive is not a guarantee you'll see an improvement :)
    What resolutions are you looking to run and we can make some suggestions.
    Best regards
    Joe
  4. steve0
    steve0
    Sep 11, 2004
    762
    Loughborough
    +32
    The Panny 6 only goes upto 800*600 resolution so any ideas on a cable :smashin:
  5. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    now, ive been doing A LOT of research on DVi cables over tha lastfew days and discoverd that there are 5, yes, 5 :eek: kinds of DVi cables.
    here: http://www.datapro.net/techinfo/dvi_info.html
    I found that it does in fact depend on your needs. for example, my plasma requires a Dual 24pin DVi-D cable to work.
    This is the best type of DVi cable as it accepts the highest resolutions.
    Also try and keep it as short as possible to avoid signal degredation.
    By the way, a more expensive cable IS better, as long as its the right type.
    But then im a cable fiend :devil:
    Have a look here to get an idea:
    http://www.pacificcable.com/DVI.htm#DVI-D_Single_Link
    This is good too, for high end cables:
    http://www.monstercable.com/home_av/video_cables//HDTV_digital.asp
    and one more:
    http://www.ramelectronics.net/html/DVI_monitor_cables.html
    So many cables :zonked: heaven!
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,579
    The Borders
    +3,030
    Steve O - you can input 1024x768 @ 60 Hz and let your Display down convert it to fit on the 852x480 display.
    I have to say that due to the lowish resolution of your display its always going to be a compromise when running PC software - everything will look soft and loose detail.
    I'd probably in this instance stick with the cable supplied with the DVI board.
    AML - so an expensive cable will make a difference 'if its a good one'. Is that not the same as 'more expensive is not a guarantee you'll see an improvement'.
    Best regards
    Joe
  7. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    Heheh. Personaly i dont mind spending 100 quid on a cable! Why? coz I can!
    Its really just peace of mind that you are using the best possible cable!
    I know that what you say is true, but as a general rule, a more expensive cable tends to be better than a cheaper cable.
    Keep it simple!
  8. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    I would have thought a lindy dvi cable would fit the bill nicely. Check them out at www.lindy.co.uk
  9. steve0
    steve0
    Sep 11, 2004
    762
    Loughborough
    +32
    Thanks for everyones help, you all been great :blush:
    I better get shopping.
    One question How can I get my panny running at 1024 by 768
    Thanks again
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,579
    The Borders
    +3,030
    steve0
    Set the PC to output 1024x768@60Hz.
    Best regards
    Joe
    PS Samir - you cant assume anything with DVI cables! and again I don't see anything Lindy offer that's going to improve on the DVI cable provided by Panasonic.
