DVI Cable problem.
Discussion in 'Projectors, Screens & Video Processors' started by malcolm, Oct 11, 2003.
  1. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    hi guys,
    in my rush to get my HTPC running as quickly as possible i popped in to Maplin this morning to pick up a DVI cable.
    They only had on in stock. male to male.
    When connecting to my HS10 i'm unable to pick up a signal.
    does this cable look correct?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Malcolm,
    That looks like a standard DVI-D dual link cable so it should be up to it. What length is it as DVI is really limited to 7.5m?
    Steve
  3. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    cheers steve, its 2m. I'll try it again.
  4. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    West Midlands - Stourbridge
    +332
    Hi Malcolm,
    that lookslike my cable.
    I shall post more later, watching England now.
    Rob
  5. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    cheers for taking a look Rob,
    I have the PJ picking up the signal now.
    Unbelievable difference over the other inputs! Been watch a bit of Monsters inc. and you couldn't wipe the smile off my face with a cricket bat!
    My latest issue is the res. I can only achieve 1024x768.
    The pj is reading the digital input.
    I'm using power strip to try to achieve 1388x788.
    Im new to PS so i'm not sure if i've set it up crrectly.
    I've created a custom res and the desktop changes when applied, but the PJ won't change from 1024x768.
    So the desktop is cut short at one end.
    I'm going to read some threads to try and find the answers.
    If you have any suggestions though.....
  6. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    ok,... got it working at 1368*768.
    Still not 1:1 mapping though. I'll try some more settings!
    Rob do you use power strip? If you do and you get 1:1 pixel mapping could you let me know what your settings are!
    Mal
