dvi cable link
mstevens
I have a Humax LGB-32TPVR and would like to know how I should connect my Computer to it via the DVI input.
The TV has a DVI-D Input and I'm unsure what type of Graphics card I should add to my PC to enable a connection between the two devices ? Is there a
certain type of card i should use as I know that there is a DVI-D to DVI-D cable on the market but does this mean I am restricted to using a Graphics card with a DVD-D output or are there other options ?
Any help would be appreciated.
Mike
most graphics card have a DVI-I output which is compatible with both DVI-D and DVI-A, so you simply need a DVI-D to DVI-D cable to connect your graphics card to yout tv...
mstevens
so from what you say there a DVD-D cable connection will slot into a Graphics card with a DVD-I output ?
