DVI Cable advice
Discussion in 'Desktop & Laptop Computers Forum' started by Lexeus, Aug 15, 2005.
  1. Lexeus
    Lexeus
    Jun 25, 2004
    542
    Crumlin, South Wales / Bristol
    +7
    hi,
    I just bought a Sony HS10 projector about a week ago and should be getting a sff pc to use with it tomorrow.
    now I have a 9800Se AIW which has a DVI output on it so I want to get a DVI cable to use with this to connect to the DVI input on the projector.
    Now I believe its a DVI-D dual link cable i want. I have been looking about and i am on a pretty tight budget so i dont want an outrageous bettercables one or anything, but what do you think of this?:
    http://cgi.ebay.co.uk/5m-DVI-cable-...799035735QQcategoryZ41999QQrdZ1QQcmdZViewItem
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=41999&item=6783997790
    Now it says it will work with both DVI-I and DVI-D sockets, but I was under the impression that a DVI-D dual link cable had more pins than a DVI-I and therefore it wouldnt fit the socket?
    and to finish, is this too cheap to be true ? or would it do the job...?
    http://cgi.ebay.co.uk/4-5M-DVI-D-DU...799214135QQcategoryZ67859QQrdZ1QQcmdZViewItem
    really appreciate any advice!
  2. meansizzler
    meansizzler
    May 11, 2005
    7,582
    104
    London
    +266
    as I believe it thereare Five type of DVI Cables
    DVI-D Single Link
    DVI-D Dual Link
    DVI-I single Link
    DVI-I Dual Link
    DVD-A
    As I understand it you only Need DVI-Dual link when you need to get an image with a resolution higher than 1280*1024, but both your display and Graphics card must support this, Unfortunately the radeon 9800 only does single link DVI, so you better off just getting a DVI-D Single Link cable, that will do the job..
    This Cable should do the Job...
  3. Lexeus
    Lexeus
    Jun 25, 2004
    542
    +7
    My 9800Se AIW has all 24 pins rather than the 18pins for single link, and I would want higher than 1280x1024 as my Sony Hs10 is something like 1366x1060
    Any more views on this please ?
    edit: oh, and I need a cable minimum of about 5m so that one would be a bit short :rolleyes:
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    With the sort of resolutions a graphics card is capable of, why would you limit the abilities of the DVI connection by making it single link only? Both my DVI cables are fully wired (a Belkin for my Plasma and a non branded lead on my pc) and the type of connection on the kit sorts itself out. I would go with the E-bay listed cable and try it. You can always upgrade later.
  5. SeanT
    SeanT
    Jan 28, 2005
    6,125
    Coventry
    +371
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,037
    The Borders
    +2,516
    Hello all
    Lexeus - what is 'outrageous' about the BetterCables Display Magic cables? If you meant the price is outrageous then please indicate a range of cables that match the BetterCables performance for less money :)
    Dual Link DVI is only of use in CAD applications and the like where you have a Dual Link Graphics Card and Dual Link Display - Hands up anyone on AVForums who has a Dual Link Display!
    If you want a relatively low cost 5m DVI cable then Molex is an excellent choice - though keep in mind you would not be the first HS10 owner who had problems with even moderate length Digital cables.
    Your Sony Projector has 1366x768 pixels so setting your PC to anything 'higher' is unlikely to result in optimal performance.
    Best regards
    Joe
  7. Lexeus
    Lexeus
    Jun 25, 2004
    542
    +7
    So the £9 ebay one would be ok right ?
    If i can find another?
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,037
    The Borders
    +2,516
    Lexeus
    There is no way of knowing if these cables will work in your system and if they work will they cause any signal drop out or degradation.
    The only way to know is to plug one in and see what you get on-screen.
    Best regards
    Joe
  9. Lexeus
    Lexeus
    Jun 25, 2004
    542
    +7
    ok, thanks for your adivce :) think i may try getting one
    You say people with HS10's have had probs ? Do you mean picture degredation ? 4.5m isn't that ling is it ?
  10. Gordon @ Convergent AV
    Jul 13, 2000
    13,981
    +2,785
    Lex: DVI was designed to go from a PC to a monitor 1-2m away. Anything at higher than XGA res going more than 2-3m needs to be checked in situ with partnering equipment at res you want to use. It's not unheard of for cables to work when tested across a floor then for the image to get sparklies when run in a loft near a lighting cable.....cheap cable, poor screening, poor connectors and conductors.....If you can get money back on your ebay stuff fire away...if you can afford to bin the cable if it doesn't work then fire away.....if you want peace of mind then why not find a vendor who'll lend you cable to try. I use Bettercable for my long runs in installations and I use Molex for standard short lengths. I never feel ripped off.
    Gordon
  11. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    Joe,
    If memory serves me right you posted elsewhere [I couldn't find 'elsewhere'] that you were "considering" Lindy's DVI cable.
    Have your considerations reached a conclusion yet?
  12. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,037
    The Borders
    +2,516
    Hello Kolabere
    Still considering our options - the lack of support for 1080P on the single link 'Premium' DVI cables could be an issue for many customers in the long term.
    I suppose if folk are willing to forgo 1080P compatibility then its a viable option.
    Best regards
    Joe
  13. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Me!
    Lovely Apple 30" Cinema Display monitor, 2560x1600 pixels of goodness. Unfortunately PC needs a 'workstation' class card, rather than 'desktop' class graphics card to drive it. :devil:
    StooMonster
  14. JackOTrades
    JackOTrades
    Jul 14, 2004
    75
    9
    London
    :clap:
    we were bound to have one amongst us...
    brilliant!
    :smashin:
    Jack
  15. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    So what are the best dual-link DVI cables on the market?
    What differentiates DVI cables? Shielding?
    StooMonster
    PS: I use my dual-link monitor to play Half-Life 2 etal at super high-res :) Oh, and open Excel with a blank sheet 84 rows high and 39 columns wide (column 'AM').
  16. lisag
    lisag
    Jul 14, 2004
    5,673
    Essex
    +331
    I have got the Lindy Premium DVI-D cable connecting my HTPC to my plasma, and I can playback 1080p video ok. :confused:
    lisa
  17. Mr.D
    Mr.D
    Jul 14, 2000
    11,049
    +1,126
    I bought a 12m dvi-d cable from cablesolutions in the states. It works a treat from my HTPC to a sony hs20. No sparklies. They do a range of sizes up to 15metres.
    They also trade on ebay.Which is where I found them after losing out on a 10m bettercable one ( production meetings happen at the most inconsiderate times)
    total price including shipping was $177 dollars plus 30quid on top for tax and duty.
