DVI board for Panasonic P6
Discussion in 'Plasma TVs' started by NeilMcRae, Nov 14, 2003.
  1. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Anyone bought one of these recently ? Has the firmware fixed been applied so that you get the correct resolution? Thanks!
    Regards,
    Neil.
  2. andybryant
    andybryant
    Dec 30, 2002
    9
    Bishop's Stortford
    Bump-tiddly-ump. Also interested in the same question.
    I'm trying to get to grips with the best way to drive a plasma at native resolution from a HTPC. I think DVI has got to be the best answer, but if the DVI i/p doesn't support NR, then it isn't.
    Also - I've been away from the boards for a few months, and in my absence, we've got a new interface standard (HDMI).
    Is HDMI cross compatible with DVI (for video only... obviously)?
    Cheers, Andy.
  3. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    any resellers care to comment?! Money is waiting if this issue has been resolved!
  4. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Panasonic are testing the DVI board tomorrow. TAG are on board (excuse the pun) since the PSM module is not compatible, and I know Pana have a pixel perfect card so that all resolutions can be tested with all plasmas. However, these things do take time to investigate, generate fixes, re-test etc etc so don't expect answers any time soon - but at least we know something positive is definitely being done....
  5. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Thanks Liam please keep us informed!
  6. BertG
    BertG
    I have been expecting an answer for over 3 months now.
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,011
    +2,808
    I can get several resolutions working in DVI but the 852x480@60 I can't get geometrically correct......and at 50Hz it's a mess....
    Gordon
  8. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    gordon,
    please don't tell me you replaced your 433MXE with PW6
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,011
    +2,808
    OK I wont. I do have a D6 sitting in front of me that I am investiagting though....
    Gordon
  10. BertG
    BertG
    Driving it with what?
    Apart from a 2 pixel overscan on each side my SD is pixel perfect at 856x480. The display and DVI card is capable of native resolution, it (currently) isn't capable of telling anything what its native resolution is.
    The other issue I had is with the DVI card in slot 2 picture adjustments (width etc) are not remembered - it is OK in the other slot.
  11. Gordon @ Convergent AV
    Jul 13, 2000
    14,011
    +2,808
  12. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    BertG,
    Could you expand on your experience as you seem to be the only one who managed to get the DVI board on D6 do the job
  13. BertG
    BertG
    I posted most of at the time (3 months ago).
    I got the TY-42TM6D DVI card for connection to an HTPC. I got a cheap Radeon 9000 Pro II card for the DVI out.
    The Radeon would only drive the display at 640x480, 800x600 or 1024x768. I searched around for any information and utilities I could use to get the card driving it at some other resolution (including powerstrip) and failed. I tried the display on a Matox Parhelia and only got 1024x768 but I didn't search for any tweaks or tools for the Parhelia. DVI being all new and plug n play compatible it seems graphic cards take the information provided by the display on the DVI interface as gospel and the DVI card says it supports 640x480, 800x600 and 1024x768 all at 60Hz and nothing more.
    I even pulled the display data pins out of a DVI cable to prevent the graphics card getting the information and the card refused to acknowledge the display was connected.
    I then started to investigate what this data from the display was and how it was held on the DVI card. I found it is covered by a VESA standard and found enough information and tools to understand and edit it. I also found the data is held on the DVI card in a small serial EEPROM which is more or less directly connected to the DVI socket (It can even be programmed via the DVI socket). The information is know as Display Information Data (DID or the extended version EDID).
    I edited the data to include a description of the display's natural resolution guessing at some of the timings and after a couple of attempts I was happy with the result and have been using it ever since.
    This is the descriptor I added
    (54-71) Detailed Timing / Descriptor Block 1:
    856x480 Pixel Clock: 33.55 MHz
    __________________________________________________
    Horizontal Image Size: 920 mm Vertical Image Size: 518 mm
    Refreshed Mode: Non-Interlaced Normal Display - No Stereo
    Horizontal:
    Active Time: 856 pixels Blanking Time: 208 pixels
    Sync Offset: 72 pixels Sync Pulse Width: 128 pixels
    Border: 0 pixels Frequency: 31.53 KHz
    Vertical:
    Active Time: 480 lines Blanking Time: 46 lines
    Sync Offset: 14 lines Sync Pulse Width: 12 lines
    Border: 0 lines Frequency: 59.95 Hz
    Digital Separate, Horizontal Polarity (-) Vertical Polarity (-)
    I don't know if it is right, or optimal but it works for me. I have been waiting for Panasonic to come up with what they think it should be.
    I set it to 856x480 not 852x480 to match what the Radeon can generate but I suspect the Radeon would interpret 852 as 856 anyway.
    After adjusting the display width and height on the Panasonic it is pixel perfect with a 2 pixel overscan on each side. I also noticed that these width and height adjustments were forgotten as soon as I switched inputs or changed modes - just to spite me after doing all that work it seemed, however, in desperation I tried the DVI card in slot 1 rather than slot 2 and it then remembered the settings.
    In my experience the apart from the forgotten settings issue the DVI card has no problem driving the display in native resolutions providing you can convince whatever you are driving it with to do so.
    I have no idea if other DVI sources use or require DID information, I would think it likely.
  14. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    Not sure if Panasonic needed to adjust DID info on the card (am trying to get this confirmed, but soooooo busy) but using a Pixel Perfect card with DVI connection, they had no problems achieving 852*480 on the 42PWD6, 1024*768 on the 42PHD6 and 1366*768 on the 50PHD6.
    They also got themselves a High Def video server and ran 720P and 1080i (high def MPEG2 with a bitrate of more than 20Mbps!!!) via DVI and were basically gobsmacked :D
    A note was made that the iScan Ultra and TAG PSM Module were apparently incompatbile due to these processors outputting a 572P rather than a 576P resolution (from a PAL video source, NTSC is fine). So the only problem is that the card will not have any joy with a 572P signal which it seems the SiL504 chip generates via DVI (it generates 576P via prog scan component).
  15. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,426
    The Borders
    +2,593
    Hello all
    The 'issue' with Graphic Cards and compatibility with the TY-42TM6DB DVI card seems to be about how most graphics cards address the display in groups of 8 Pixels - which the Pixel Perfect card doesn't do.
    Pixel Perfect cards are designed for wide screen displays and offer 1:1 pixel mapping.
    Panasonic have offered to test other graphics cards - though I know Panasonic have already talked to Radeon who said their cards (even with Powerstrip) wont resolve 1366 as its not divisible by 8 (though as BetrG reports he has a Radeon working so maybe BertG needs to go educate Radeon :) )
    Trust this helps.
    Joe
  16. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
  17. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,191
    38
    +3
    Do people still think that the panny 6 is still not a good choice at the moment for the DVI connection or do you think panny are going to sort the problem out & offer some sort of upgrade?
  18. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,426
    The Borders
    +2,593
    Hello Andy
    The 'solution' is to use a Graphic Card that is designed for use with Wide Screen displays - or so I'm told.
    Best regards
    Joe
  19. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,191
    38
    +3
    Sorry i was refering to the use of a dvd player with DVI output.
  20. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    Andy,
    The DVI input is fine with my Momitsu player at 480p, but I don't think you'll be able to tell beforehand if any given player will work out of the box, e.g. just by reading specs.
    It's all a bit hit a miss at the moment - this DVI/HDMI stuff is still a little green right now, and interoperability seems to be a bit of a gamble.
    Cheers, Carl.
  21. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    I have a Radeon running at 1366x768 at 60,70,72,75,80Hz on Panny5 50" via VGA; was not a problem to setup in PowerStrip at all.
    StooMonster
  22. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,426
    The Borders
    +2,593
    Hello StooMonster
    Should have been clearer its 1366 x768 via DVI on the 6 Series that's the problem - VGA is no problem as you say.
    Best regards
    Joe
  23. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Hence my quote, and mention of VGA. :)
    Interesting on the SiI504 output at 572P though, how strange is that?
    StooMonster
  24. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    The Iscan ultra actually has two 480P resolutions as well :)
  25. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    Yes it does, it changes the width of the output resolution from 720x480 to VGA 640x480 (some displays only accept computer resolutions via DVI). It does the same for PAL sources too, switching between 720x572 and 640x572 (although the manual quotes 720 or 640 wide by 576 lines).
  26. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Liam
    didn't know that about PAL on the ultra, have they tweaked this? If so good, if not I must read the manual more closely :)
  27. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    give us your email addy and i'll mail you a copy
  28. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,191
    38
    +3
    Sorry to sound a bit thick but i'm no tech head, am i right in thinking that at present the panny 6 will not accept a PAL signal ( R2 dvd ) from a dvd player via the DVI port, or am i as thick as i think i am.
    Andy
  29. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    If the DVD player takes a PAL source and purely deinterlaces it without any scaling etc, in theory the picture should be a 576P signal which is no probs.
    The iScan and TAG module when they take a PAL signal, for some reason convert it into a 572P signal with a lump of excess blanking attached to it - it is this signal that the Panasonic DVI card does not understand.
  30. BertG
    BertG
    I have a Radeon running at 856x480 which is divisible by 8 and results in a 2 pixel overscan on each side. It will also do 848x480 giving a 2 pixel margin each side. I don't see why a Radeon won't do 1368 giving a 1 pixel overscan on the 50" panny.
    I don't see that overscanning 1 or 2 pixels is any kind of problem. The problem is the DVI card doesn't tell the graphic cards what the display native resolution is so it being able to generate it or not is a bit irrelevant.
