DVI Auto Switcher
Discussion in 'Cables & Switches' started by richjthorpe, Jan 10, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hi all,
    Are there DVI Switch boxes that have auto switching ? The only ones I've seen either have a button to press or a remote control. Is it not like SCART where there is a pin to switch to ?
    Thanks,
    Richie.
  2. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    I haven't had the need for DVI (yet) and the only thing I could find was this:
    http://www2.dvigear.com/dvi2x1switcher.html
    but it is very expensive and I don't know if it's auto switching or whether it's available here (uk)
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,805
    The Borders
    +2,471
    Hello Richie
    How many sources do you need to switch? - there may be a solution that has 'priority' switching depending on what source kit is switched on!
    Another option could be a Zektor DVS5.1 - it uses Push button, IR or RS232; though the IR option lets you program the box to react to IR commands from another device.
    If you have an AV Receiver in the set-up and use that to switch audio the DVS5.1 can be 'taught' to switch in tandem with the AV Receiver.
    See http://www.zektor.com/dvs51/index.htm
    Best regards
    Joe
