DVI And VGA Connections
Discussion in 'Projectors, Screens & Video Processors' started by Jim Cheese, Jul 20, 2002.
  1. Jim Cheese
    Jim Cheese
    Dear All,
    My PC has a DVI output only on it's video card. So I have to use a DVI/VGA adaptor.
    My projector (Sony VPL CS2) has a VGA input.
    Hence currently I use an analogue cable to connect from the PC to the projector.
    Would I get a better image quality if I used a digital cable from the DVI output into a DVI/VGA adaptor on the projector?
    TIA
    Mark
  2. Kramer
    Kramer
    Not really.
    All cables pass an anologue signal (fibre optics excepted), so you're no going to improve things unless you're PJ has a DVI input.
    Plus, you're limited to a maximum cable length of 2 meters with DVI (I know longer are available, but the're VERY expensive, & can only pass up to a certain resolution at a given length).
  3. Jim Cheese
    Jim Cheese
    Many thanks! :)
    M
