DVI and AE500 Resolution Issue
Discussion in 'Projectors, Screens & Video Processors' started by firstwave, May 18, 2004.
  1. firstwave
    firstwave
    Trying to get my htpc setup via DVI on the AE500.
    I am using a ASUS Radeon 9800XT card.
    When connection the DVI to a TFT monitor, I can set a resolution of 1280x720 with no problem.
    However, if I try this on the ae500, I do not get an option to select 1280x720 - it makes no difference if I set it to EDID1 or 2.
    Any Ideas? I take it I am doing something really stupid, but cannot work it out.
    thanks
    Darren
