DVI advice
Discussion in 'Desktop & Laptop Computers Forum' started by jpfrost, Apr 24, 2005.
  1. jpfrost
    jpfrost
    Jan 18, 2003
    93
    I have looked at my DVI socket on my PC and determined that it is DVI-I (is this pretty standard?).
    Does this mean I can use a DVI-D OR a DVI-I cable to connect to plasma screen? Does one offer better quality than the other?
    Thanks.
  2. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    Yes.
    If your screen has a DVI-D socket then you wont be able to put a DVI-I connector into it.
    If it has a DVI-I then you can chose either.
    For preference use a DVI-D cable, single or dual.
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I don't think I've seen a normal consumer card with a DVI-D, they do exist on high-end profession workstation type devices but you'd not spend >£1K to watch DVDs. :)
    As for quality, I assume you know the difference betwen them, the quality is the same since DVI-I is simpy a superset of DVI-D.
