DVHS Dtheatre - conections to BG808?
Discussion in 'Projectors, Screens & Video Processors' started by NickBull, May 31, 2002.
Thread Status:
Not open for further replies.
  1. NickBull
    NickBull
    As my BG808 only has the 5 BNC input (I think) how would you connect the DVHS Dtheatre VCR to the projector?
    I am monitoring how this is going in the US and if it looks like taking off I might be tempted to buy one and import a few films.
    Any info would be great
    Nick
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I suspect these will out put either on an HD15 plug like a VGA connector or will come out component.
    If the forma is the case then just via the standard input or the 2nd RGB port three.
    If it is the latter then you will need a high bandwith compenent to RGB converter as the BG808 does not take component. (you need an "s" version for that)
  3. NickBull
    NickBull
    How much are the converters?
    I can see I may be waiting for HD DVD if thinsg start adding up.
    I'll research the VCR a bit, see what the connections are.
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
  5. Old Projector
    Old Projector
    Nick, output is Component on 3 RCA phones. Most tapes, including the demo tape, are at 1080i which the 808s does not handle correctly so you are no worse off with the non "s" projector. There is no fix for the "s" not dealing with 1080i Component acording to Barco, you have to have a Component to RGB transcoder capable of 1080i and 720p with at least a 50Mhz RGB bandwidth. Altinex TR6102HD is the one I use. If you go D-VHS be prepared to bin every DVD you own! Terminator 2 releases 6th of June with loads more to follow very soon.
    Henry
  6. harry_thx
    harry_thx
    @Henry
    Do I understand your posting correct? Although the 808s can handle component singals it still needs a converter, because it will only handle 1080i on his RGB inputs?
    I have a 808, a friend of mine the 808s. We both think about upgrading to the JVC HDTV. Till today I thought that only I need a converter and that my friend can go the direct way.
    Is there any difference ( technique, bandwith, quality and price) between the KeyDigital, which I want to use and the Altinex?
    Do you have a Link for Altinex informations?
    Harry
  7. Old Projector
    Old Projector
    Harry
    The 808s accepts Component but for some reason it does not deal correctly with 1080i, the image is very dark indeed. Barco are aware of this I think and it's a well documented problem. The Key Digital transcoder is much cheaper than the Alitinex unit and looks fine for the job, only draw back is outputs are HD15 connectors which limit you to minature cables. Altinex are at www.alitnex.com
    Henry
Thread Status:
