DVE - What exactly does it do?
Discussion in 'General TV Discussions Forum' started by knoxy, Aug 21, 2004.
  1. knoxy
    knoxy
    Nov 6, 2002
    201
    Manchester
    +31
    I've seen this phrase mentioned a few times across the forums and i'm guessing it helps set up video equipment?
    Will it simply calibrate my telly for dvds or will it come back with a report on the best settings for me to change?
    Getting a new telly and want to get the best from it - both for general viewing an watching dvds - oh and using my xbox!
    Is it worth it? I see its for sale in the power buys section.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,209
    +3,045
    Digital Video Essentials is a DVD with test patterns and audio tones that allow you to set up your audio and video system accurately. There is a commentary you can listen to that tries to explain what is important and educates you in how to use the tools on the disc. It is available in 480i(NTSC) and 576i(PAL) versions.
    Gordon
