DVE, PAL or NTSC does it matter ?
Discussion in 'General TV Discussions Forum' started by gtfc, May 14, 2004.
  1. gtfc
    gtfc
    Just ordered a new PD32PD30C. I've got mostly R2 with a few R1 DVDs.
    Does it matter if I try to calibrate the TV with the DVE NTSC disc and then play PAL versions and vice versa ? (I assumed the disc helps to set correct colour levels and geometry levels that are generic).
    Or is it more involved than that.
    Many Thanks
    GTFC
  2. Chris5
    Chris5
    Mar 21, 2004
    1,290
    63
    Herts., uk
    +179
    I believe with most tvs, gtfc, settings for NTSC are stored seperately from PAL, so if you calibrate with NTSC DVE disk, then it will make no difference to PAL DVDS and visa-versa
  3. cerebros
    cerebros
    Dec 27, 2002
    1,314
    48
    Leicester
    +30
    It probably depends on your set.
    With the JVC HV32P37 I had briefly, the geometry settings certainly needed setting differently for PAL & NTSC, but feeding it via component, I found that colour/contrast/brightness was constant between the two. I did have to use one of the custom settings to adjust these settings to get the best from RGB feed from my 221T & X-box.
  4. Paul Atreides
    Paul Atreides
    Yes.
    It will be correct for NTSC only.
  5. gtfc
    gtfc
    Thanks peeps, just ordered my PAL version.
  6. aliasnow
    aliasnow
    sure, Paul?
    how can I check this?
  7. Paul Atreides
    Paul Atreides
    The colour will be different, and maybe geometry.
    It's best to have PAL if you want PAL correct.
