DVE PAL and NTSC
Discussion in 'Plasma TVs Forum' started by DaveBB, Feb 14, 2005.
  1. DaveBB
    DaveBB
    Jan 1, 2005
    94
    +12
    Just bought PAL DVE from Piero who has also advised that I need to do a NTSC set up too if I am to play Region 1 discs with a better calibrated screen. However, I want to understand how you switch between the PAL and NTSC calibrated set ups (do you adjust normal mode to PAL and Cinema to NTSC or vice versa or something else?). I have:
    Pansaonic 50" Viera
    Panasonic SCHT1500 Multiregion.
    Input greatly appreciated!
    Dave
  2. DaveBB
    DaveBB
    Jan 1, 2005
    94
    +12
    Anyone got a clever ploy for this or is it a manual switch between normal and cinema each time you use a Region 1 disk as opposed to a Region 2 disc?
    Someone else must play multi region dvds!!!!
    Dave
  3. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    with normal picture settings on the viera, what ever you adjust for pal will also be the same for NTSC.
    If you are doing a pro calibration in the service menu, then an NTSC disc and PAL disc will be benificall.
