Bearded_Malc
Established Member
- Joined
- Aug 10, 2004
- Messages
- 393
- Reaction score
- 20
- Points
- 97
- Age
- 66
Just got my DVE disk (I'll get my plasma later, room not ready yet ) and I was getting to grips with it. There are a few issues.
1. No gamma adjustment. Paint shop pro has a good way of doing this IMO. It displays 50% red green and blue, and 100% red green and blue dithered to 50%. You adjust gamma until the two look the same intensity. (So I guess I'll connect my PC).
2. No set white balance, set mid range balance or set black level balance. I guess you could use the % grey boxes for that. It would have been useful to provide a grey test card or one of those photograph test cards for comparisons. Especially for checking the white balance. Of course you would need to view under daylight or a daylight temperature bulb but that is not difficult.
Are these there, that is have I missed something on disk? Is the AVIA better?
I have some freeware for setting my monitor but other than brightness and contrast it mostly doesn't apply to plasmas. I wonder if there is any other useful software on the net specifically for Plasma/TVs. Anyone know?
